Emergency Responder 7.0 FTP or HTTP installation (CER)
Dec 24th, 2008
Has anyone successfully installed CER 7.0 via FTP or HTTP? I am able to connect to my FTP server, but the Red Hat anaconda installer exits due to a file that it could not find (update.img). If i review the FTP server log s files, i can see the server connect and log in to the correct directory and begin the installation process. After the installation begins and loads the Redhat/base/stage2.img files the installation halts with a Line 19 error message.
Also I am using a HP DL320 G5 server. I know that the CER 7.0 installation does not support SATA DVD-rom, so that's why I had to result to a FTP installation.
