Upload Prompt Feature in IPCCX Fails after upgrade from 4.0 to 5.0.2
Dec 24th, 2008
I had a recording script I use that worked in 4.0.5. However, once IPCCX got upgraded to 5.0.2, the upload prompt feature within the script fails. I have authenticate user and password setup before this node so Im not sure if anyhting's changed in terms of requirements from the upgrade...
Overall Rating: 5 (1 ratings)
jbayuka Tue, 12/30/2008 - 09:47
  • Bronze, 100 points or more
Can you upload prompt manually via AppAdmin? What errors you are getting when uploading the prompt is failing?
SAN J Tue, 12/30/2008 - 12:41
Yes, I can upload the prompt files manually without any issues. There's no actual errors I can see when I run the reactive debug. ALl it does is it goes to the "unsuccessful" path each time after it hits the upload prompt node. The authentication I have in front of it is successful as well so I'm not sure what I'm missing if any...
mymite060708 Wed, 02/18/2009 - 06:06
I am getting the same issue. auth works but upload goes to unsuccessful each time
any ideas?
Chris Deren Wed, 02/18/2009 - 07:43
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
The authentication method was changed in UCCX 5.0, User ID requires variable of type user rather than string.
HTH,
Chris
SAN J Mon, 02/23/2009 - 13:35
I tried using the following steps to no avail:
1. Get User - where User ID is a string variable and Output User is a User variable.
2. Authenticate User - where User is same as Output User variable mentioned above and Password is a string variable.
3. Upload Prompt - where User is same as Output User variable menitoned above.
Still not working but manual upload does. Again, this was working just fine on 4X version. Is there a specific way the User setup needs to be before the Upload Prompt?
webberr Thu, 11/05/2009 - 13:01
I'm having the same issue - did you ever resolve it?
Thanks - Rob.
SAN J Thu, 11/05/2009 - 13:09
Remove the "Get User" if you're using it. I ended up just using the Auth User with the user variable being USER[name] and the password being a string.
webberr Thu, 11/05/2009 - 14:24
Thanks for the reply. So the "user" portion of the AuthenticateUser step seems to be looking for a String. Did you enter USER[username] directly into the step, or in that step did you reference a String variable that was USER[username]?
Thanks - Rob.
SAN J Thu, 11/05/2009 - 14:50
I pointed both entries to the variables. I used a "User" type for the username variable with a value of USER[name] and "string" type for the password with a value of "password". Hope that helps...
webberr Fri, 11/06/2009 - 05:01
That did the trick - use an Authenticate User step right before the Upload Prompt step. For the User use a variable of type "User" with a value of USER[username]. For Password use a variable of type String with a value of "password".
Thanks for your help!
Rob.
