vlan protocol down on NM-16ESW port installed in 3725 router
Answered Question
Dec 24th, 2008
Hello all,
I have been struggling with a problem and not sure how to fix this.
I have confirmed etherswitch nm-16esw mod in 3725 router. I have created 2 vlans for voice and data under vlan database. I have created SVI's for these vlans on the router and define ip helper-address.
I have two IP phones connected with etherswitch port 1 and port 2 so that they can send the dhcp request to register over the WAN with Call Manager.
Now the issue is I couldn't get the VLAN data and voice to be up up. The line protocol is constantly down on them.
I am running c3725-adventerprisek9_ivs-mz.124-3j on 3725. Following are my configs:
interface Loopback0
ip address 10.61.65.254 255.255.255.0
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
description SiteB-Ph1
switchport trunk native vlan 63
switchport mode trunk
switchport voice vlan 306
spanning-tree portfast
no routing dynamic
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Serial2/0
no ip address
encapsulation frame-relay
serial restart-delay 0
no dce-terminal-timing-enable
frame-relay lmi-type cisco
interface Serial2/0.102 point-to-point
ip address 172.1.2.2 255.255.255.0
frame-relay interface-dlci 102
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Vlan1
no ip address
interface Vlan92
description Data Vlan
ip address 10.106.65.254 255.255.255.0
ip helper-address 10.6.64.11
interface Vlan104
description Voice Vlan
ip address 10.206.65.254 255.255.255.0
ip helper-address 10.60.64.11
router ospf 1
log-adjacency-changes
network 10.0.0.0 0.255.255.255 area 0
network 172.0.0.0 0.255.255.255 area 0
=================vlan database=========
VLAN ISL Id: 92
Media Type: Ethernet
VLAN 802.10 Id: 100063
State: Operational
MTU: 1500
VLAN ISL Id: 104
VLAN 802.10 Id: 100306
State: Operational
MTU: 1500
Also, I have noticed that etherswitch ports fa 1/7 and fa 1/15 keep flaping even though I have not configured anything
Correct Answer by richard.m.gilbert about 8 years 4 weeks ago
If I understand it correctly, you have a phone and a computer plugged in on both interface 1/0 and 1/1? If so, I think you want to have those interfaces configured as shown below ...
switchport access vlan 92
switchport voice vlan 104
switchport mode access
no routing dynamic
no routing dynamic
As for fa1/7 and 1/15 ... have you taken the module out and blown out the bay in the router as well as the module? That might help.
Overall Rating: 5 (1 ratings)
glen.grant Wed, 12/24/2008 - 19:47
A lot of times you do not trunk the access ports that the phones are attached to . Set it up as a access port vlan 92 with a voice vlan 104 and get rid of the trunk statement and see what happens . If the SVI isn't up usually the port is not connected. I didn't understand the voice vlan setup , on the ports you have the voice vlan as 306 yet your definition in the vlan database and the SVI say 104 .
sakengineer Wed, 12/24/2008 - 20:29
Thanks Glen.
Please read the voice vlan as 104 and data vlan as 92. I copied the old configuration for fa 0/1 and fa 0/2.
I'll give it a try and will update you.
SAK
Correct Answer
richard.m.gilbert Wed, 12/24/2008 - 21:51
no routing dynamic
no routing dynamic
