VLAN priority on the Catalyst 2950 trunk port
Dec 25th, 2008
Hello!
I have a Catalyst 2950 switch. It have one ethernet port with trunk:
interface FastEthernet0/1
switchport trunk allowed vlan 2,92
switchport mode trunk
spanning-tree portfast trunk
The port is connected on radio-channel with 2 Mbps bandwidth. The Vlan 2 have big traffic every time.
Can i do that all traffic on Vlan 92 will have MIN 64 kbps free bandwidth every time on this radio-channel?
Thanks. Dev
Giuseppe Larosa Thu, 12/25/2008 - 09:12
  • Hall of Fame,
    Founding Member
Hello Dev,
you would need modular QoS to do that and I don't think C2950 supports it
So, I may be wrong, but I don't think you can do it.
Edit:
actually 2950 supports modular QoS inbound so if you can classify and mark traffic on the internal vlans/ports you can then provide some resources to traffic marked in some way.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea11x/configuration/guide/swqos.html#wp1044930
however, this can work outbound direction only.
on traffic received on fas0/1 you have few to none control.
Hope to help
Giuseppe
DevDimonTSNG Thu, 12/25/2008 - 09:31
Ok, I will study this more later. I hope I will can to resolve this problem by QoS
