Problem with Non Gatekeeper Controlled InterCluster Trunk
Dec 25th, 2008
We have a two different setups one running ccm 4 and one running cucm 6. there is a non gatekeeper controlled intercluster trunk between ccm4 and cucm6, call managers are configured in publisher and subscriber scenario. Trunk is configured between publishers at both end.
Network running cucm6 has three subscribers, when we try to make a call from phones registered with subscribers every second call is completed. When i checked network capture result on subscriber and publisher I came to know that calls being load balanced between publisher and subscriber. When call is initiated from publisher its completed when its initiated via subscriber in goes uncompleted.
Also in one region calls are only going through subscriber so 100% failure on these calls.
Any idea how it can be resolved.
gogasca Thu, 12/25/2008 - 16:11
  • Green, 3000 points or more
Hello sir,
CUCM 4.X --- CUCM 6.x
"Trunk is configured between publishers at both end"
First of all, you need to check the configuration of the ICT. Example
CUCM 4.x CUCM 6.x
Server1A Server1B
server2A Server2B
server3A Server3B
When you configure the ICT in 4.x cluster.
Them Remote IP Addresses should contain ALL
Remote servers )1b,2b and 3b)
When you configure ICT in 6.xyou need to configure the remote IP Addresses of 1A,2A, 3A-
You can check our srnd guide for more information
iftikharsyed_2 Thu, 12/25/2008 - 20:24
Thanks for your reply, do you mean that I will have to give IP address of all subscribers as well?
Iftikhar Ahmed
