What all is applicable in a Context Configuration
Dec 25th, 2008
I am trying to define a probe with request method in non-admin context. The option is however not available.
Could someone please state that what all configurations used in Admin context can also be applied in the non-Admin context. Is there any table mentioning it ?
Overall Rating: 5 (1 ratings)
Syed Iftekhar Ahmed Thu, 12/25/2008 - 12:00
Apart from resource allocation & context creation you can do pretty much all SLB related config in any context.
What config are you trying to put in and what are you getting?
Syed Iftekhar Ahmed
cisco_lite Fri, 12/26/2008 - 11:10
I made a mistake. I was using probe tcp instead of probe http therefore, request method was not showing up.
Thanks.
