Can a layer 4 policy block IM traffic in IOS firewall?
Dec 25th, 2008
Hi experts,
My customer wants to allow messaging just for certain users IP and block it for anybody else. His configuration is something like the following:
class-map match-all msn
match protocol imap
match access-group name Permited_MSN
ip access-list extended Permited_MSN
deny ip host 192.168.1.x
permit ip any any
policy-map msnmap
class msn
interface BVI1
ip address
ip pim dense-mode
ip nat inside
ip virtual-reassembly
service-policy input msnmap
Doing a show policy-map, we never see matched packets being dropped.
Cisco1811W#show policy-map interface bvi 1
Service-policy input: msnmap
Class-map: msn (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: protocol imap
Match: access-group name Permited_MSN
Class-map: class-default (match-any)
1722583 packets, 929916071 bytes
5 minute offered rate 612000 bps, drop rate 0 bps
Match: any
Should this configuration work? Can the router block MSN like traffic with a layer 4 policy or it is necessary to use zone-based with application policy?
Any comment on this is highly appreciated.
Overall Rating: 3 (1 ratings)
The class map "MSN" will not work, The config is trying to match imap AND the access-list. IMAP has nothing to do with MSN.
Confirmation it is not working is in the policy-map lines:
"0 packets, 0 bytes"
To be honest using QoS (which is the policy map) is not the way to block this type of traffic. MSN has specific ports - depending on the version. The latest versions of MSN or Live Messenger will use HTTP.
jopontes Fri, 12/26/2008 - 09:47
Thank you Andrew!
I figured that this configuration had nothing to do with what the customer wants.
I am now configuring using the zone-based policies.
Configuring an Instant Messenger (IM) Policy
However, this seems to have only match-any clause, which does not give the option to tie an acl to take an action only on certain IP traffic.
Is there any other way to accomplish it?
