12-25-2008 01:23 PM - edited 07-03-2021 04:55 PM
hay
I have two WLC 4000 configured as failover.
does the configuration synchronize between the two WLCs?
Solved! Go to Solution.
12-26-2008 07:18 AM
No it doesn't sync configuration.... you need to configure each wlc and make sure that both are in the same mobility group in order for the ap's to know of both wlc's.
You would need to configure the access points with a primary, secondary or tertiary wlc, in order for that ap to know which wlc it should be joined with.
12-26-2008 07:18 AM
12-26-2008 12:19 PM
thanks fella
12-26-2008 12:23 PM
It is also not a transperant failover since ap's will have to join the secondary or tertiary wlc.
