I want to do CCNP
Dec 25th, 2008
I have a valid CCNA and would like to do CCNP how many exams are required and which exam(s) should I take first that is the sequence in order.
babatunde_sanda Thu, 12/25/2008 - 23:58
You will need to take and pass four exams to be awarded the CCNP certification. This URL shows the exams. https://www.cisco.com/web/learning/le3/le2/le37/le10/learning_certification_type_home.html
The order of the exams is not important but it is advised you take them in this order BSCI, BCMSN, ISCW, ONT. I would recommend you follow this path too personally. This order will help your understanding of the concepts and technologies (it helped me).
Good luck.
