VWIC2-1MFT-T1/E1 on 1721
Answered Question
Dec 26th, 2008
I've a problem with this daugter card on a router Cisco 1721. In fact the router doesn't recognize this card.
******* Sh ver ********
IOS (tm) C1700 Software (C1700-K9O3SY7-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
*******sh diag ********
Slot 0:
C1721 1FE Mainboard Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 4.0
PCB Serial Number : FOC08383JC5
Part Number : 73-7546-04
Board Revision : A0
Fab Version : 04
Product (FRU) Number : CISCO1721
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 5A 41 04 00 C1 8B 46 4F 43 30 38 33
0x10: 38 33 4A 43 35 82 49 1D 7A 04 42 41 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC/VIC Slot 0:
Unknown
Daughter card-Version 4 TLV Cookie Format
Hardware Revision : 0.0
Top Assy. Part Number : 800-22628-05
Board Revision : B0
Deviation Number : 94603
Fab Version : 04
PCB Serial Number : FOC1216165M
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-1MFT-T1/E1
Version Identifier (VID) : V01
WIC/VIC Slot 1:
Serial 1T
Hardware revision 1.0 Board revision J0
Serial number 0023147339 Part number 800-01514-01
FRU Part Number WIC-1T=
Test history 0x00 RMA number 00-00-00
Connector type WAN Module
EEPROM format version 1
0x20: 01 02 01 00 01 61 33 4B 50 05 EA 01 00 00 00 00
0x30: 98 00 00 00 11 11 02 01 FF FF FF FF FF FF FF FF
I don't understand this problem.
Please, someone can help me?
Thanks in advance.
Regards.
Correct Answer by Giuseppe Larosa about 8 years 4 months ago
Hello Marc,
the minimum version is 12.3(14)T you had a 12.3(26) mainline.
T is for technology train.
New features and new cards are introduced in the T train and then later integrated in main release.
You can find in 12.4 mainline the support of what has been introduced in 12.3T
Bonnes Fetes a Tous
Hope to help
Giuseppe
Correct Answer by cisco steps about 8 years 4 months ago
here is your file . again, do not delete the old one t'l this one is confirmed working .,, good luck and bon chance VZ
IP BASE
c1700-ipbasek9-mz.124-23.bin
Release Date: 12/Nov/2008
IP BASE
Size: 11603.01 KB (11881480 bytes)
Minimum Memory: DRAM:64 MB Flash:16 MB
Overall Rating: 5 (2 ratings)
Giuseppe Larosa Fri, 12/26/2008 - 07:09
  • Hall of Fame,
    Founding Member
Hello Marc,
in the following link the compatibility matrix
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00800ae37f.shtml
notice that the following is supported
VWIC-2MFT-E1
but yours is VWIC2-1MFT-T1/E1
the following
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
declares support on C1721 for data services only
it is an IOS problem see table 1
minimum IOS for 1721 to support the VWIC2
12.3(14)T
So you need to perform an IOS upgrade to support the module
Hope to help
Giuseppe
cisco steps Fri, 12/26/2008 - 08:39
Marc, giuslar is right,,, I have 3745 router w/ VWIC2-MFT-T1/E1 that was not been reconize due to iso .. here is the one lastest one for my 3745..ipbase ios ..
c3745-ipbasek9-mz.124-23.bin
One more thing your are in france so you may be using E1. I do not know if europe config and language are the same as USA.. bone chance mon ami :-)
Correct Answer
cisco steps Fri, 12/26/2008 - 09:09
IP BASE
IP BASE
marcOfBouloc Fri, 12/26/2008 - 11:07
Many thanks guys. Your replies were very helpfull for me to solve my issue.
In fact, I was missed with the vesrsion of the card I search on Cisco website (VWIC-2MFT-E1
instead of VWIC2-1MFT-T1/E1). Now I put the IOS c1700-ipbasek9-mz.124-23.bin and the card works fine !!!!!! Hourreyyyyyy !!!!
Just something I don't understand : onto the matrix compatibility, it is indicated that I need a IOS 12.3(14)T or earlier. My router was using a 12.3(26) Version and it didn't work? Could you please explain me that fact?
Thanks again. and as we said in France "BONNES FETES A TOUS"
Correct Answer
Giuseppe Larosa Fri, 12/26/2008 - 12:43
  • Hall of Fame,
    Founding Member
Hello Marc,
Bonnes Fetes a Tous
Hope to help
Giuseppe
marcOfBouloc Sat, 12/27/2008 - 01:20
Many thanks for these explanations Giuseppe.
Kind regards.
Marc
