HSRP
Dec 26th, 2008
what does it happen if HSRP is activated and host continues to use one of the routers real IP address (not the virtual one) as default gateway?
Nunzio
Jon Marshall Fri, 12/26/2008 - 03:33
Nunzio
The host will still be able to communicate with other subnets/vlans and it will function correctly. But if the physical interface that the host is using goes down then the host will lose connectivity to the rest of the network.
Jon
krish2008 Sat, 12/27/2008 - 22:32
Simply corresponding host is not using HSRP feature, and have a single gateway only.
