VPN Concentrator issue
Dec 26th, 2008
I have VPN concentrator 3000 with 4.7.2 vers and I have enabled webvpn for my users.
My query is:
If user having windows 2000 OS they able to connect thru webvpn and if it is windows vista they are able to login after that java page is not loading...its not getting connect.
pls let us know if any body experienced the same issue..
sateesh
didyap Wed, 01/07/2009 - 13:10
Some Java Applets verify that the server which is being used to download the Applet matches a list of pre-defined servers before allowing applet execution to occur. Take a look at this bug CSCec25478.
