Cannot start Unity
Answered Question
Dec 26th, 2008
  • Bronze, 100 points or more
I just changed the passwords for the accounts in unity. Unityadmin, unitydirsvc, unityinstall, unitymsgstore. I restarted the server. Now Unity will not start. Its saying smething about login failure when i attempt to restatrt the services.
What else can I be looking at. Any help appreciated.
Correct Answer by ranpierce about 8 years 4 months ago
Run the service configuration wizard from tools depot on the desktop of the Unity server.
first is dirsrv. second is msgstore, and third is local system.
Hope this helps
Randy
Correct Answer by Bradford Magnani about 8 years 4 months ago
Babatunde,
If you change the passwords to these accounts, this will directly affect the services that were using the old password credentials. You will need to re-run the Services Configuration Wizard in the Tools Depot and enter the new passwords for the accounts.
Hope this helps. If so, please rate.
Brad
Overall Rating: 5 (2 ratings)
Correct Answer
Bradford Magnani Fri, 12/26/2008 - 09:45
  • Cisco Employee,
Babatunde,
Brad
babatunde_sanda Fri, 12/26/2008 - 09:52
I just ran the Services Configuration Wizard. I then attempted to restart unity from the tray but it still fails. And when i try from the services.msc too it still says failure to start becuase of login
babatunde_sanda Fri, 12/26/2008 - 10:09
Ok guys after running the Services Configuration Wizard and Unity still didn't start, I went int the services.msc and manually changed all the passwords that I see is pointing to the domain accounts. I then restarted. Unity is up. Thanks guys.
Correct Answer
ranpierce Fri, 12/26/2008 - 09:45
  • Silver, 250 points or more
Hope this helps
Randy
