Can sticky and cookie insert be a L4 process?
I currently have sticky and cookie insert as a layer 7 process. I would like to know if I can configure sticky and the cookie insert as a layer 4 process to consequently improve performance?
My current config:
class-map type http loadbalance match-any L7-URL
2 match http url .*.
policy-map type loadbalance first-match prod-powerimage
class L7-URL
sticky-serverfarm Sticky-Insert-Cookie
insert-http src-ip header-value "%is:%ps:%id:%pd"
class class-default
serverfarm prod-server
litrenta Mon, 12/29/2008 - 08:07
  • Cisco Employee,
You don't necesarily need to match on url (you can use class-default)But the act of cookie insert and cookie sticky as well as inserting a header will keep it L7.
