Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928832members
1242685discussions
Community Activity
DUO offline keeps looping
Hi. Our end-users suddenly has issue with DUO offline, it keeps on looping on the offline page. This only occurs on end-users who are on overseas or outside Singapore. Initially, they can log-in to their DUO, however after few days, they're already p...
PaulWP by Level 1
  • 69 Views
  • 1 replies
Meraki Duo SSO through SAML
I'm tryign to set up Duo SSO for Meraki Client VPN, the knowledgebase seems out of date as it refers to choosing the Applciation Protect page when currently it's meant to use SAML. I have a few items I am not 100% sure where to get1) I think the enti...
CDragna by Level 1
  • 44 Views
  • 1 replies
Duo Desktop not recognized
Hello, I am using Cisco Anyconnect to connect to VPN. The system is using Duo Desktop for device health. It is already installed, running and all the checks are ok. However, I am getting this error message and not able to proceed: Install Duo Desktop...
Sh2024 by Level 1
  • 62 Views
  • 1 replies
Allow ISE captive portal DNS entry on outside DNS.
Hello,We are having ISE for EAP/TACACS authentication and, hosted internally in our datacenter.Now we have configured BYOD captive portal that tied to AZURE SAML authentication, the current captive portal redirect URL from ISE has prepended the node ...
kshah2589 by Level 1
  • 1515 Views
  • 26 replies
AP9115axi
Hi ,I am facing one issue. AP9115AXI (access point) acquired IP address from DHCP. Confirmed with ARP table on switch.But  the command sh cdp nei detail - doesn't show IP address of AP. AP not yet associated to WLC.Any suggestion?With Regards,Ravindr...
odd loopback errdisable issue
My company has 4 Call Manager subscribers, two at our HQ datacenter and two at our colocation.   We powered down everything at our colo this part Saturday because we are moving it out of state.  Since then, we have had random locations having switch ...
Cisco CM Switch Box
Our Forum Alert III Secondary Crash Net (SCN) is inoperable. I've heard the cisco cm could be configured to set up some devices to act as a ringdown, they called it a “Switch Box.” This would allow our Base Operations guys to have a work around from ...
Configuring NAT overload with vrf lite on a CAT9K
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 305 Views
  • 13 replies
9800 WLC-Same Vlans on multiple sites in SD-WAN setup
I have a 9800-CL in an SD-WAN setup. I have multiple sites that have the same Vlans at each site to make it easier to manage and remember.Ex:NorthSite: data-4, voice-5, wifi-6SouthSite: data-4, voice-5, wifi-6etc...My current WLC configuration has on...
GeorgeC71 by Level 1
  • 111 Views
  • 4 replies
Resolved! Dual ISP connection gi0/2 not able to connect to internet
Hello,I need your help - currently we have a  2921 Cisco router connected to dual ISPs using "gi0/0 & gi0/1" and we are able to connect to either ISP successfully.  Once we connect gi0/2 to any device the connected switch is not able to access the in...
dgrant524 by Level 1
  • 88 Views
  • 9 replies
WLC 5508 licenses
I have a WLC with 11 registered access points I tried to integrate a new equipment, but I see that I already have my 37 licenses in use. Can you guide me and let me know what this is due to?there is a way to release licenses from the WEB portal or...
angelalmaras_0-1713897847230.png angelalmaras_1-1713898066080.png angelalmaras_2-1713898103303.png
