No information coming while i put a show diag in cisco C7201.
Answered Question
Dec 26th, 2008
No information coming while i put a show diag in cisco C7201 router..Is there any alternate command available?
Router#sh diag
no info showing..
Correct Answer by Giuseppe Larosa about 8 years 4 months ago
Hello Stalin,
be aware that C3560 is a fixed configuration device (not modular)
sh diagnostic
provides the results of system tests
show version
can provide some informations about the processor board and so on.
see command reference for your version
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_35_se/command/reference/cli2.html#wp8361286
Hope to help
Giuseppe
Hello Stalin,
try to use the following
show c7200
Hope to help
Giuseppe
Overall Rating: 0 (2 ratings)
Rupesh Kashyap Sat, 12/27/2008 - 01:17
Hi, What you want to do, please clarify.
You can run Sh Version command.
stalin_cisco Sat, 12/27/2008 - 02:10
Normaly when i put show diag command.The router hardware information ( mother board & etc.) will come.But in this case not coming any info..it is showing blank...
Router # show diag
See the below show diag output from different Router series..
Router # sh diag
Slot 0:
C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : FOC12373GQ1
Hardware Revision : 1.0
Top Assy. Part Number : 800-26921-03
Board Revision : A0
Deviation Number : 0
Fab Version : 03
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20080913
Chassis Serial Number : FHK1239F166
Chassis MAC Address : 0023.3313.eac0
MAC Address block size : 32
CLEI Code : COM7M00ARA
Product (FRU) Number : CISCO2821
Part Number : 73-8853-05
Version Identifier : V04
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 32 33 37 33 47 51 31 40
0x10: 03 E8 41 01 00 C0 46 03 20 00 69 29 03 42 41 30
0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 69 11 C2 8B 46 48 4B 31 32 33 39
0x40: 46 31 36 36 C3 06 00 23 33 13 EA C0 43 00 20 C6
0x50: 8A 43 4F 4D 37 4D 30 30 41 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22 95
0x70: 05 89 56 30 34 20 D9 02 40 C1 FF FF FF FF FF FF
WIC Slot 0:
Serial 2T (12in1)
Hardware revision 1.0 Board revision J0
Serial number 29710137 Part number 800-03181-01
FRU Part Number WIC-2T=
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 12 01 00 01 C5 57 39 50 0C 6D 01 00 00 00 00
0x30: 98 00 00 00 03 01 13 00 FF FF FF FF FF FF FF FF
Correct Answer
Giuseppe Larosa Sat, 12/27/2008 - 13:17
  • Hall of Fame,
    Founding Member
Hello Stalin,
show c7200
Hope to help
Giuseppe
stalin_cisco Sat, 01/03/2009 - 22:24
Thanks for the reply.Using the above command we can find the harware info...We have another one switch C3560 for purpose of CE router.here also show diag cmd not working.
Please help me for the same..
IOS version :- Cisco IOS Software, C3560 Software (C3560-IPSERVICES-M), Version 12.2(35)SE5.
Correct Answer
Giuseppe Larosa Sun, 01/04/2009 - 02:54
  • Hall of Fame,
    Founding Member
Hello Stalin,
sh diagnostic
show version
Hope to help
Giuseppe
