Agent desktop failing to login to IPCCX 7.0
Dec 26th, 2008
Hi, I have this issue with my IPCCX server that no agents can login to it. When trying to login using Cisco Desk top Agent. It comes with an error “The ID you entered was not found” very strange.
I have CUCM 6.1 AD integrated.
IPCCX 7.0 Premium
User is configured properly as I was able to assign them to Queues and some of the users are admins as well, they can successfully login to the admin page and appuser page.
Any idea in what could be the issue in here. Much appreciated for your help.
Also see attached log file
Nour
Chris Deren Sat, 12/27/2008 - 08:14
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Are these users appearing in appadmin page as resources?
Chris
mnour401917_2 Sat, 12/27/2008 - 16:20
Yes i see the users appearing on the resources page of appadmin.
Thanks!
jardalic1 Mon, 01/12/2009 - 03:58
I have the same problem. Did you find any solution?
thx,
Jelena
peyjremario176 Mon, 01/12/2009 - 05:01
i encountered same and found some misconfiguration on CUCM device association with username.
jardalic1 Mon, 01/12/2009 - 06:12
what kind of misconfiguration?
I have user associated with device and device with user, do I need sth else?
Also under the user I have IPCC extension
Thx,
Jelena
