Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929535members
1244140discussions
Community Activity
copy xmodem initializing no transfer c2960
Hi Guys, i had this problem for 8 hours now and can't seem to get it cracked... after i input the command copy xmodem: flash:c2960-lanbasek9-mz.152-7.e9.binand using the SecureCRT going to Transfer > send xmodem I get this and after that nothing happ...
ACI multipod with vPC HA FW
Hi All, I need your assistance to check if the following configuration going to work and are there any drawbacks/caveats?So far I identified OSPF convergence time and impact on a relatively large area 0 *(legacy design). Solution details:I have ACI M...
wireless authentication
hello I am working in an environment where there is a wireless guest infrastructure configured  guest users are given access by an Administrator based on their email  there is  a requirement for a wireless printer to be given access to this guest net...
The operation took longer than expected.
I have just synchronized both Active Directory and Cisco ISE, ISE is using my server (AD) as an NTP server, everything is fine, but now I'm facing an issue "Status Summary: The operation took longer than expected. This may be caused by slow network c...
Jason2005 by Level 1
  • 246 Views
  • 13 replies
IPSEC VPN
Hello Team,I have below topology : -I have ipsec vpn from on-prem to aws cloud. the two endpoints  [192.168.40.10/32, 192.168.30.10/32] work fine as they are allowed on the encryption domain.I have users using remote vpn to connect to on-prem dc to a...
fmugambi by Spotlight
  • 74 Views
  • 12 replies
Expressway Single Domain 2 Seperate Expressways
Hi,We have a customer using HCS. As part of this we set up Expressway for them during the first lockdown for them to be able to use Jabber remotely for voice only (no IM&P). They use the same domain name internally and externally e.g. abc.com Another...
mikee2112 by Level 1
  • 411 Views
  • 1 replies
Catalyst 9000: NetFlow において Inactive flows がタイムアウトされない
2024年4月23日 (初版) TAC SR Collection主な問題 Catalyst 9000 シリーズの機器において uptime が一年以上になっている場合、 NetFlow においてInactive flows のキャッシュテーブルがタイムアウトされず、残り続ける可能性があります。 原因 この問題は CSCwa64171 として報告されております。 解決策 回避策:再起動によりタイムアウトされます。恒久対策:CSCwa64171 の不具合が修正されているバージョンをご利用くだ...
CISCO WSA upgrade alert error
We have upgraded our S1000v(wsa ) from 14.5.1 to 14.5.2 and upgrade was successful but when we checked the alerts we found an alerts as An application fault occurred: ('heimdall/svc.py send_command|195', "<class 'heimdall.exceptions.unknownprocess'="...
DK9 by Level 1
  • 93 Views
  • 6 replies
CMX - cmxadmin password recovery 11.0
I am following this document to recover and reset the password for "cmxadmin" https://www.cisco.com/c/en/us/td/docs/wireless/mse/11-0-1/cmx-config/b_cg_cmx1101/performing_administrative_tasks.html#id_131101 When I reset my VM Server and edit ("e") in...
Duo Desktop not recognized
Hello, I am using Cisco Anyconnect to connect to VPN. The system is using Duo Desktop for device health. It is already installed, running and all the checks are ok. However, I am getting this error message and not able to proceed: Install Duo Desktop...
Sh2024 by Level 1
  • 110 Views
  • 4 replies
Multipod L3Out Preference
Hi All,I'm currently deploying ACI Multipod with two pods.I've configured a single VRF and single BGP L3Out that connects the leaf switches within each pod to our core network. This L3Out is then assigned to each BD which results in the the associate...
dm2020 by Level 1
  • 160 Views
  • 3 replies
cannot get to privileged enable mode via console
After searching through other posts, my config seems OK but still strange behaviourasa 9.20 running on FPWR chasisI cannot get in enabled mode when connecting to ASA via console.It used to work but stopped after I played (disable and restore) with aa...
kewwa by Level 1
  • 123 Views
  • 5 replies
Repeating syslog Message and then Crash
We're seeing a continuous string of the following messages on a 9407 running 17.9.5.  Eventually the switch crashes.  I can't find any info on what these messages mean exactly and whether we're looking at a software or hardware fault.  The supervisor...
