SSL VPN Login Error Message
Dec 27th, 2008
Periodically, I have received reports that SSL VPN users receive the following message and are unable to login:
" Logout
Goodbye.
For your own security, please:
clear the browser's cache
Delete any downloaded files
Close the browser's window "
The software versions used are shown below.
Show Flash output on the ASA firewall
galleria2-lab-fw-gw# sh flash
--#-- --length-- -----date/time------ path
63 14635008 Jun 26 2008 09:48:02 asa803-k8.bin
6 8192 Aug 14 2007 06:13:50 crypto_archive
64 7295568 Jun 26 2008 09:50:16 asdm-611.bin
2 8192 Jun 26 2008 09:52:20 log
66 2153344 Aug 15 2008 10:19:06 anyconnect-win-2.2.0136-k9.pkg
255426560 bytes total (230891520 bytes free)
Can anyone provide some recommendations for troubleshooting this problem?
JORGE RODRIGUEZ Thu, 01/01/2009 - 14:07
  • Green, 3000 points or more
You may want to start with this link.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00809888e5.shtml
Since you said periodically does that means same ssl clients can successfully connect some days and cannont connect other days? I would try looking at ASDM logs specifically stick with a webvpn user that cannot connect and see the logs..
Also ensure you are not going over your SSL vpn licensing limits just to rule this out, but it sounds more of a client browser issue, in any case start narrowing down by using above link.
