Multiple SSID and Multiple VLAN
Dec 28th, 2008
Dear All
I just want to create two SSID with two different VLANs , on AP 1121G , and broadcast the two SSID , how can i do it ?
i know that in my switch, the point connected to AP must be trunk , do i need to create BVI ?!!!
and do i need to make ethernet port trunk in AP if yes How ?
i read almost all documents but i cant get it to work
motasemkhater Tue, 12/30/2008 - 00:15
Thank you vey much , i will try it know ,
but if i do this , I will get 2 SSID on my "Avaliable Wireless Network "
or i need to add the second SSID to every wireless client
motasemkhater Tue, 12/30/2008 - 02:20
i try it and its working just fine ,
the problem that i cant make the AP to brodcast the 2 SSID ?!!
they always hidden ,, with VISTA its ok , because i got "UNNAMED Network" in avaliable wireless connection ,
but in XP i tried to add SSID many time , but noting shows up. ?!!!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
