cat6509 switch sup redudnacy
Dec 28th, 2008
Hi I have a switch 6509 with 2 SUP 720B at slot 5&6. Is this work as a redundant only? If i need both sup engine to be work together for load balancing, is it possible? if yes how can we achieve that?
Jacob Samuel Mon, 12/29/2008 - 07:27
Thanks for the update i was asking about RP Active/Active mode only. I got it confirm from 6500config guide also.
thakns a lot
bilousand Mon, 12/29/2008 - 06:21
What load balancing? All ports on both supervisors are active independent from redundancy mode.
