12-28-2008 08:34 AM
I would like to identify the latest connections in the 'show conn' table. Does the table build up in a linear fashion i.e. the latest con is the last row. Can timestamp be enabled on the 'show conn' display. Also, how is the conn id generated. I don't see it in sequence.
12-29-2008 06:58 AM
The conn id is normally sequential.
But there are 2 IXP and both have its own conn_id counter.
Moreover, we re-use connid that have been freed when a connection is closed.
You could do a 'show conn detail' and look at the "elapsed time: 145:49:29".
The highest value will be the first connection.
G.
12-30-2008 04:35 AM
Thanks. Could you please explain what is IXP.
12-30-2008 08:07 AM
ACE is actually the combination of 3 CPU.
The Control Plane (CP) which is the management side - holds the configuration, answers snmp queries, sends probes,...
The IXP are the 2 CPU actually switching the traffic.
They are also called network processors or NP.
This is the 2nd column of the 'show conn'.
Gilles.
