B-ACD transfer to external destination
ggcruijsen
Hello
We are using the B-ACD AA feature for a time now without problems.
Because of a reorganization we have to change one of the menu options.
Instead of transferring the call to an available agent on a the ephone-hunt we have to transfer the call to an external number.
Is searched the documentation and forum but didn't find a way to configure.
( I am aware of the Alternate extension option Voicemail) this is not an option its used to deliver call coverage for the other options in the menu.
Gerrit
Not applicable
You can transfer-calls from B-ACD AA to external number using the following config. Once call is transferred to external number, it is a blind transfer and the call will not be queued.
application
service bacd flash:<>
param aa-hunt <>
dial-peer voice <> pots
destination pattern <>
port <>
