Route FXS port to dedicated FXO port
Dec 28th, 2008
I have a UC500 with CME7. There are 3 connected FXO ports and 1 FXS port as fax.
The IP phone does not have to dial a prefix for an outside line. The fax should always use the 3rd FXO port.
How can I configure a dial-peer / voice translation so that FXS port 0/0/0 always uses FXO port 0/1/3
without dialing a prefix like 9 or so.
Thx
Filip
Nicholas Matthews Mon, 12/29/2008 - 09:13
  • Red, 2250 points or more
Hi Filip,
You can use cor lists to do this, or you can use translation patterns.
The idea is for the fax machine to dial a normal number, the router will add a prefix for routing, match the appropriate dial peer, and then strip the prefix before sending it out. This is transparent to either end.
It would look something like this:
voice translation-rule 1
rule 1 /\(.*\)/ /9999\1/
voice translation-profile 1
translated called 1
dial-peer voice 1 pots
port 0/0/0
translation-profile incoming 1
dial-peer voice 2 pots
port 0/1/3
destination-pattern 9999.T
What happens:
Call from FXS hits dial peer 1, router adds 9999. Router searches for a dial peer that matches the 9999.* number, finds dial peer 2. On a pots dial peer, any number explicitly matches is stripped, so the number sent out is the original dialed number.
hth,
nick
