ASA - Help - RIP Not Sending Default Route Info.
Dec 28th, 2008
Hello.
I'm in the process of replacing PIX with the ASA. I have configured RIP and have it working up to a point. I receive RIP updates from other devices, but unlike the PIX ver 6, the ASA does not send out default route info. Currently the PIX sends out default route info pointing to it's inside interface to the downstream router. What could i be doing wrong? Below the current RIP config on the ASA. I should also add, the ASA has a static default route set pointing to the outisde interface peer router. I'm looking to have the ASA advertise to downstream routers a default route pointing to its inside interface.
router rip
network 172.25.0.0
passive-interface Inside
default-information originate
version 2
ASA#
htarra Fri, 01/02/2009 - 09:47
  • Bronze, 100 points or more
RIP: default-info originate - if static default route present, it won't work
For further reference please follow the bug CSCsj20597.
