Troubleshoot IPCC Enterprise
Dec 28th, 2008
Hi all,
I troubleshooting following this link http://cisco.com/en/US/products/sw/custcosw/ps1001/products_tech_note09186a00800acafa.shtml . But this command doesn't work.
My log is:
C:\>opctest /cust vinph /node pg1a
OPCTEST Release 7.2.5.0 , Build 20485
18:01:39 Fail: Unable to CreateFile connection to (\\.\pipe\ICM\vinph\pg1a\OPCIn
put).
Last API Error [2]: The system cannot find the file specified.
I don't understand what "ICM node name" is and where this command is typed (on Router or Logger or PG). "ICM node name" is hostname of server , isn't it?
Please advise me,
Thucnk_FPT_FIS_6 Thu, 01/01/2009 - 08:25
Hi David,
Yes, My hostname PG server is hanapg1a, ICM customer instance name is vinph. But the command doesn't work.
I wonder Hostname is Node ID, isn't it?
joesnyde Mon, 01/05/2009 - 10:44
  • Cisco Employee,
Hostname is the name of the computer. The node name is the actual node, i.e. pg1a, pg1b, pg2a, etc...
You need to have admin rights on the box you are trying to run the opctest utility. Example of syntax:
c:\>opctest /cust icm /node pg1a
webstd.design Thu, 04/30/2009 - 05:28
Hello. I want to export info from ocptest to txt for parsing and monitoring with Network Monitoring System - is it possible?
Thank you!
