12-28-2008 10:43 PM
there is firewall between GSS primary and GSS backup, can some one tell me which port (TCP/UDP?) need to be opened to allow two GSS communicate?
thanks
Solved! Go to Solution.
12-29-2008 04:09 AM
There is a chapter on this topic in the administration guide, located here:
It lists all the ports that need to be opened inbound and outbound for a GSS when all services are active. Note that depending on which services you run you may not need all these ports to be open.
Andrew.
12-29-2008 04:09 AM
Andrew.
