VPN error invalid spi urgent help
Dec 29th, 2008
we are running MPLS VPN using Tunnel0 interface , we go the frequent below error message in router conole , it seems clinet end router holding old SA, it is not refereshed. pl advise, urgent
INCDR#
*Dec 29 09:19:11.134: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=192.168.118.62, prot=50, spi=0x2968B91(43420561), srcaddr=10.51.105.1
*Dec 29 09:20:55.197: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=192.168.118.62, prot=50, spi=0x27BD4575(666715509), srcaddr=10.51.105.1
*Dec 29 09:22:50.185: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=192.168.118.62, prot=50, spi=0xB243ED01(2990796033), srcaddr=10.51.105.1
INCHENNAIDR#
INCHENNAIDR#ping 10.51.105.1
Brent Rockburn Mon, 12/29/2008 - 12:15
You can try "crypto isakmp invalid-spi-recovery"
Also if you're problem is the client holding old sa's I suggest you put in "crypto isakmp keepalive 10 periodic"
deccankarthik Mon, 12/29/2008 - 23:37
i have already configured "crypto isakmp invalid-spi-recovery "
now i have added "crypto isakmp keepalive 10 periodic "
i will update the result soon , other wise the client has to clear the SA in their router.Is it correct ?
Brent Rockburn Mon, 12/29/2008 - 23:59
What is the problem you're having exactly. The invalid SPI maybe not be the issue rather the symptom of a bigger configuration problem. Can you post your confi, or maybe describe the network a little more?
