Is it normal that users whant to send 20 pages by fax??
Dec 29th, 2008
I see that fax can send normal 2-3 pages. But not more.
FAX is VG224 configured as SCCP.
What Can I do to do some tuning for increase number of pages that users can send?
Chris Deren Mon, 12/29/2008 - 11:45
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Sure it's normal, you can send as many pages as you want. SCCP does not play very well with faxing, my suggestion would be to use MGCP or H323 for them. Also, ensure your egress voice gateway is configured properly, i.e. consistent faxing protocol is used throughout your environment, i.e. passthrough, relay, etc.
HTH,
Chris
webstd.design Mon, 12/29/2008 - 13:21
What is the best practice for fax configuration?
1)Forexample if I use VG224 - What can you advice? SCCP/MGCP,T.38/passtrhough...etc? What
2)Forexample if I use Voice Gateway with FXS port - 28XX/38XX series? MGCP/H.323, T.38/passthough/...etc?
