General Question regarding BVI & Dot11
Dec 29th, 2008
Hi There,
I have a general question concerning BVI & Dot11 interfaces on a 871W. I had to configure a Subinterface for the radio Interface to get he box running. This is the point which is a little confusing to me. Why do I have to work with subinterfaces to bring the radio up. Is it not possible to attach the radio interface to the bridge-group without using subinterfaces? There is only one VLAN (Vlan1 / native) in which all internal interfaces (fe & radio) should be member of. In order to bring the radio up I had to configure a subinterface for the radio and put this one in the bridge-group & Vlan. When I tried to to the same with the radio interface itself it did not come up (reset Status). Can anybody tell me why I need to use subinterfaces in this case? I like to understand.....
Thanks...Andy
mark.cronin Mon, 12/29/2008 - 05:14
Andy
The BVI sub-interfaces map directly to the vlans that you create ie
BVI10 - VLAN 10
BVI20 - VLAN 20 (Guest WLAN)
This allows you to have 2 SSID WLANS which I think is the maximum for the 871W
Mark
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
