UC500 fax problem.
Dec 29th, 2008
Hi, i have a problem, i configurated the uc500 to recive fax to a extension... this have a dial-peer with
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 777
b2bua
no modem passthrough
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
fax-relay sg3-to-g3
fax-relay ans-disable
fax rate disable
fax nsf 000000
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
no vad
when i try to pass a fax to the extension, start the negociation with the fax ( tones like modem ) but never finish, keep the tones and never get connected..
this is the debug::
Dec 27 16:44:25.923: 0/1/0 69715472 fr-entered=10(ms)
Dec 27 16:44:25.923: 0/0/0 (217) 69715474 fr-entered=10(ms)
timestamp=69716564 fr-msg-det NSF
timestamp=69716872 fr-msg-tx NSF
timestamp=69717764 fr-msg-det CSI
timestamp=69718072 fr-msg-tx CSI
timestamp=69718504 fr-msg-det DIS
timestamp=69718812 fr-msg-tx DIS
timestamp=69724694 fr-msg-det NSF
timestamp=69725002 fr-msg-tx NSF
timestamp=69725894 fr-msg-det CSI
timestamp=69726202 fr-msg-tx CSI
timestamp=69726634 fr-msg-det DIS
timestamp=69726942 fr-msg-tx DIS
timestamp=69733324 fr-msg-det NSF
timestamp=69733632 fr-msg-tx NSF
timestamp=69734524 fr-msg-det CSI
timestamp=69734832 fr-msg-tx CSI
timestamp=69735274 fr-msg-det DIS
timestamp=69735582 fr-msg-tx DIS
timestamp=69741984 fr-msg-det NSF
timestamp=69742292 fr-msg-tx NSF
timestamp=69743184 fr-msg-det CSI
timestamp=69743492 fr-msg-tx CSI
timestamp=69743924 fr-msg-det DIS
timestamp=69744232 fr-msg-tx DIS
please help!
jsivulka Fri, 01/02/2009 - 09:55
add the following modifications:
voice-port 0/0/0
connection plar 299
dial-peer voice 1 pots
incoming called-number .%
direct-inward-dial
port 0/0/0
dial-peer voice 6 pots
destination-pattern 0T
port 0/0/0
