12-29-2008 05:57 AM - edited 03-06-2019 03:10 AM
what is the use of no switch port command in L3 switch?
12-29-2008 06:01 AM
It makes the port into a routed port and you can apply an IP address directly to the port.
Hope that helps.
12-29-2008 06:07 AM
Can u give any example scenario.
12-29-2008 07:07 AM
You use it as any routed port such as on a router. Instead of using a SVI and putting a port into that vlan you put the addressing info (gateway) directly on the port interface versus the SVI. You can then just connect to any other network device like a switch for layer 3 routing in that subnet.
02-02-2009 08:44 AM
Could you provide an example of the commands one would use to configure switchport to be a routed port. Please include how you would 'put the addressing info (gateway) directly on the port'.
TIA
02-02-2009 09:05 AM
This is for a 3750
interface GigabitEthernet1/0/1
description example router port1
no switchport
ip address 10.10.10.1 255.255.255.0
no ip redirects
interface GigabitEthernet1/0/2
description example router port 2
no switchport
ip address 10.10.11.1 255.255.255.0
no ip redirects
For default gateway you can use either
ip route 0.0.0.0 0.0.0.0 "ip of default gateway"
or
ip default-gateway "ip of default gateway"
do not forget to enable the ip routing in the switch.
12-02-2012 04:09 PM
Could any one please advise the following : I almost have same issues as above.
I have 2 router connected to a 3750. Router A is hooked up with Internet and Router B is also hooked up with Internet
Current all the Traffic is going to Router A, I have connected the Router B on the 3750 and configured as no switch port and given a IP.
I was woundering how can I determine or change some traffice to go to Router B as all are going to Router A.
Below is the configuration that I have :
ip default-gateway 192.168.100.1 |
ip http server |
ip http secure-server |
ip route 0.0.0.0 0.0.0.0 192.168.100.1 |
ip sla enable reaction-alerts |
access-list 20 permit 0.0.0.0 255.255.255.0 |
access-list 40 permit 0.0.0.0 255.255.255.0 |
access-list 100 remark GUEST NETWORK CONTROL |
access-list 100 permit udp 172.20.20.0 0.0.0.255 host 192.168.171.1 eq domain |
access-list 100 permit udp 172.20.20.0 0.0.0.255 host 192.168.171.30 eq domain |
access-list 100 permit udp any any eq bootps |
access-list 100 permit udp any any eq bootpc |
access-list 100 deny ip 172.20.20.0 0.0.0.255 192.168.168.0 0.0.3.255 log |
access-list 100 deny ip 172.20.20.0 0.0.0.255 192.168.10.0 0.0.0.255 log |
access-list 100 deny ip 172.20.20.0 0.0.0.255 192.168.20.0 0.0.0.255 log |
access-list 100 deny ip 172.20.20.0 0.0.0.255 192.168.30.0 0.0.0.255 log |
access-list 100 deny ip 172.20.20.0 0.0.0.255 192.168.40.0 0.0.0.255 log |
access-list 100 deny ip 172.20.20.0 0.0.0.255 192.168.50.0 0.0.0.255 log |
access-list 100 deny ip 172.20.20.0 0.0.0.255 192.168.60.0 0.0.0.255 log |
access-list 100 deny ip 172.20.20.0 0.0.0.255 192.168.70.0 0.0.0.255 log |
access-list 100 deny ip 172.20.20.0 0.0.0.255 192.168.90.0 0.0.0.255 log |
access-list 100 deny ip 172.20.20.0 0.0.0.255 172.20.10.0 0.0.0.255 log |
access-list 100 deny ip 172.20.20.0 0.0.0.255 172.20.30.0 0.0.0.255 log |
access-list 100 deny ip 172.20.20.0 0.0.0.255 172.20.40.0 0.0.0.255 log |
access-list 100 permit ip 172.20.20.0 0.0.0.255 any |
access-list 100 remark |
12-03-2012 05:19 AM
it alll depends on you setup and the feature sets.
When you have independent internet lines you can not simple loadbalance on the 3750.
You may whant to have a look into policy based routing wiht this you can assign protocols or hosts to a specific line.
