6509 Load Balancing
Answered Question
Dec 29th, 2008
Hello guys,
How can I implement load balancing and redundancy at my two 6509 Switch?
Thanks in advance.
Cheers!
Correct Answer by Collin Clark about 8 years 2 months ago
The easiest way would be to implement VSS. It may require a Sup and/or chassis upgrade.
http://www.cisco.com/en/US/products/ps9336/index.html
Another way is to implement first hop gateway redundancy using HSRP or GLBP.
http://www.cisco.com/en/US/tech/tk648/tk362/tk321/tsd_technology_support_sub-protocol_home.html
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a00807d2520.shtml
Hope that helps.
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Mon, 12/29/2008 - 06:13
  • Purple, 4500 points or more
Hope that helps.
