Simple signatures question!!!
Answered Question
Dec 29th, 2008
Hi Cisco team,
I have a simple question to do for you. Why most signatures per default is disable? Have any explanation? Why are obsoletes? What signature I should enable and what signature I should disable?
You could help me, please?
regards,
Rodrigo Alves
Correct Answer by rmeans about 8 years 1 month ago
My thoughts in no order.
signatures set to disable by default
a. Some signatures are for vulnerabilities that are very old. The signatures would only be needed in rare instances. Setting the signature to default can save the IPS resources.
b. The quality of a signature may not be very high. If the signature is enabled, a lot of false positives might be generated thus creating frustration for the admin.
I could continue but I think you get the idea.
Which signatures should be enabled?
The signatures that meet your environmental needs should be enabled. If you are an all Windows shop, you don't need Unix oriented signatures. In addition, you should enable signatures that match your organizations security policies.
I would start with the signatures Cisco has enabled by default. As you feel comfortable the alerts, tune false positives and correct problems, enable more signatures.
Overall Rating: 5 (1 ratings)
Correct Answer
rmeans Wed, 12/31/2008 - 09:22
