2821 Scenario
Dec 29th, 2008
Please excuse my ignorance, but one must start somewhere. Am I correct in thinking that I could potentially have a 2821 Router with an AIM-CUE, an appropriate AIM-VPN module, a NM-16ESW-PWR module, an EVM-HD module with a FXO expansion, and a HWIC-AP-G-A. With those items, I would have one device that would encompass Voicemail, auto-attendant, translation between PoE IP phones and some number of analog phone lines, the ability to VPN in to the site, and have a wireless access point? Thanks in advance for your insight.
JS
Brandon Buffin Mon, 12/29/2008 - 07:44
  • Purple, 4500 points or more
JS,
Yes, the ISR routers are built to perform multiple functions as you suggest. One thing to keep in mind is that you will need Callmanager Express running on the 2821 or a Callmanager for the phones to register to to provide call signaling.
Hope this helps.
Brandon
Chris Deren Mon, 12/29/2008 - 11:41
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
I agree with Brandon, one thing to keep in mind though is single point of failure for all of your components. If you can afford it then you are golden.
Chris
