BARS in ccm version 7.1
Answered Question
Dec 29th, 2008
my backup history says the last good backup was on 12-01. when I try to do a manual back up, I receive a message that a backup is currently in progress. I try to cancel it but it doesn't allow me to. it's been processing for about a week now, how can I get it to stop?
Correct Answer by Jaime Valencia about 8 years 4 months ago
restart the DRS services, BTW there is no BARS in linux versions. it's DRF
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
webstd.design Mon, 12/29/2008 - 07:21
Try to reset CCM service on Publisher (forexample) or reboot your servers from console.
Correct Answer
Jaime Valencia Mon, 12/29/2008 - 07:48
  • Cisco Employee,
  • Hall of Fame,
    2011
java
evandro.nunes Tue, 10/05/2010 - 10:31
Yesterday, i had the same issue, then i restarted de DRF Master and local, then the problem was solved.
Does anybody know if it can be a Bug in CCM 7.1 ?
