New SIP trunk, can't hear called number ring, everything else fine
Dec 29th, 2008
We are in the process of testing a new SIP trunk.
The Gateway is configured IP2IP Gateway.
The insbound and outbound calling seems to be working fine, but when I dial an outside number, I do not hear the remote end ring.
When the remote end picks up, I hear everything fine.
Inbound calling seems to work fine.
Would this be a carrier issue, or Gateway config?
Is there a way for me to debug the Gateway and determine where the issue is?
Nicholas Matthews Mon, 12/29/2008 - 09:23
  • Red, 2250 points or more
Hi Wilson,
There are few things you can do to try to fix this problem. There aren't any details, so this is speculation:
voice service voip
h323
emptycapability
sip
midcall-signaling
On CUCM:
If H323 gateway:
Check 'MTP required'
Uncheck 'wait for far-end H245'
Enable outbound fast-start
Enable inbound fast-start
If SIP gateway:
What is probably happening is you're doing slow start or late media out, and your provider is sending in-band ringback. They should be sending a 180 Ringing, or we will need to send early media. That's what this configuration should help with.
hth,
nick
