Is FAC setup for some, not all users, possible in CUCM 5.1?
Answered Question
Dec 29th, 2008
I need to set up FAC for international calls on my Call Mgr 5.1, but only apply to selected groups. The only way I can see to do this is to duplicate my international route patterns, then create new partition and calling search space to use this new route pattern. Seems a bit cumbersome, is there any other way to set this up?
Correct Answer by Jaime Valencia about 8 years 3 months ago
no, the way you're thinking to do is is the only way. you need to separate FAC enabled route patterns using CSS and partitions.
java
if this helps, please rate
Overall Rating: 5 (2 ratings)
Correct Answer
Jaime Valencia Mon, 12/29/2008 - 08:43
  • Cisco Employee,
  • Hall of Fame,
    2011
java
