Problem with ipaq 610 hp
hi,
i have a problem with IPAQ 610 and de association with the ssid.
The problem is: i have created two ssid one of them (SSID1) no past through the nac and the ipaq is associate but after 1 minute is disassociated and in the other ssid not even associatied. The ipaq is asoccieted to one of the ssid and take IP from the dhcp server but there no have conectivitie, i mean can't navegate with internet explorer and
The ipaq try to conect to AP 1010 and is a solucion with Wireless lan controller and NAC.
the two ssid, one of them no past through the nac(ssid1) and the ipaq asociet but in 1 minute is disassociated and in the other ssid (ssid2) not even asocieted.
This ocurr with this ipaq 610 and with ipod touch and all the movile device.
Someone know why this is happen?
Scott Fella Tue, 12/30/2008 - 18:11
Take a look at the wlan session timeout and set that to a higher figure. If the ipaq and the other mobile devices connect, do they all function correctly until they get dissconnected from the AP. With NAC, devices will either need a client or the NAC will have to scan the devices. These device will not be able to pass the NAC unless you exempt these. Post your show run-config so we can see how you have your wlc configured.
Scott Fella Sat, 01/10/2009 - 09:36
Well for one, you should have the ap-manager and the management interface on the same subnet and that should be configured as native vlan on the trunk port.
What ssid are the ipaq suppose to connect to and also what interface. What is the vlan that the untrusted side of the NAC is on and what vlan is the trusted side on.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
