redisribution question
Dec 29th, 2008
guys we have eigrp and ospf running and we want that routes which is redistributed in ospof from eigrp shd have metric type 1 (E1) now i guess we can redistribute eigrp as follow
router ospf 1
redistribute eigrp XX subnets route-map red
route-map red
set metric type-1
guys i was reading online can we do the follwoing as well to achieve the results
router ospf 1
redistribute eigrp xx subnets metric type-1
will it do the same thing as above??? or we have to add route-map....thanks
Edison Ortiz Mon, 12/29/2008 - 08:38
  • Hall of Fame,
    Founding Member
Same result.
The route-map allows you more options during the redistribution. If you want to assign a metric-type 1 to all EIGRP redistributed routes, then the last option is sufficient.
If you want to include/exclude specific EIGRP subnets for the metric-type 1 assignment, then you need a route-map.
HTH,
__
Edison.
