AnyConnect without admin privileges
Dec 29th, 2008
Does anyone know of a way to install/deploy the AnyConnect client in an environment that natively does not allow users to have Administrator level privileges over their PC's?
Any help is appreciated....
Overall Rating: 5 (1 ratings)
h.parsons Mon, 01/05/2009 - 11:00
You can download the msi package and have their administrator install the package manually.
r.spiandorello Thu, 12/09/2010 - 02:00
Hi, where can I find the requirements ?
Is "pc admin priviledge" a requirement for the web anyconnect installation ?
thank you in advance
rs
Elpadre1973 Sat, 10/01/2011 - 07:51
Updating the AC client by central deployment is not helping either. When you push out a new version to all clients you have to use same version on the ASA or it will try to downgrade which will fail due to no local admin rights. And clients that did not get the update by central deployment will not be able to connect due to AC wants to upgrade.
Could elevated rights to anyconnects registry key fix this?
webabc123 Thu, 05/10/2012 - 08:47
Are there some other solutions for this issue to allow the installation to complete without giving users administrator rights such as the suggestion in the post above this one?
