UT host reporting, multiple lines for same hosts
Dec 29th, 2008
This appears to be a known issue but looks like it was supposed to have been resolved in my version, 4.0.12.
What I am seeing is some hosts showing up 2-8 times in a UT report, all with same information, but with different "last seen" info for each line.
Is there any work-around or fix for this?
thanks!
Joe Clarke Mon, 12/29/2008 - 11:31
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is a known problem, and while it was fixed, it is not auto-correctable. In order to correct the problem, the ANI database must be reinitialized after upgrading to a fixed version:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=ani dmprefix=ANI
Afterwards, you will need to run a new Campus Data Collection, followed by a new UT acquisition. The duplicates should not return.
js88888888 Mon, 12/29/2008 - 11:33
Thanks Jclarke, will this process take anything else "offline"? Don't remember what the ANI DB affects....
Joe Clarke Mon, 12/29/2008 - 11:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The Daemon Manager will need to be shutdown. Only Campus Manager data will be lost, though.
js88888888 Fri, 05/01/2009 - 11:08
I did notice that this returned not too long after this fix.
At this time, UT reports are still showing 2-6 entries for some hosts.
Should I rerun the purge again or do you know of another fix?
thanks
Joe Clarke Fri, 05/01/2009 - 11:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Some duplicates may be fine. Is the only difference between them the last seen time?
