Automate FWSM Backup
Dec 29th, 2008
I am looking for method to automate backing up FWSM configuration. Our FWSMs have more than four contexts and I am looking for backing up all of them. Although I have read old posts on this in netpro but couldn't come on some concrete conclusion and at the sametime I don't see Cisco recommendation on this. Any thoughts?
cisco24x7 Mon, 12/29/2008 - 12:05
How about RANCID? It is the best network
device configuration backup bar none.
yagnesh_tel Tue, 12/30/2008 - 08:22
Hi David,
Thanks for answering. I know it's good freeware but I doubt if it can pull off configuration from FWSM context itself. Have you tried to configure it thatway?
cisco24x7 Tue, 12/30/2008 - 08:43
Remember RANCID is a freeware and the code is
written in Expect. It can be done. You just
have to modify the code to make it work.
That being said, I've never use multiple
security context but I am familiar with it.
The way log into the device to switch security
context, you can add a new expect script to do
just that and grab the configuration. It is
relatively simple.
