POE and power injectors combined on the same link
Dec 29th, 2008
I have an existing POE capable switch (3750). A new installation of IP based video cameras will include the installation of a power injector for each IP camera. Is there a concern when inserting a power injector on an existing POE port?
Giuseppe Larosa Mon, 12/29/2008 - 13:31
  • Hall of Fame,
    Founding Member
Hello Curtis,
for safety I would disable POE on the specific port used for the camera before connecting
Hope to help
Giuseppe
ccorkern Mon, 12/29/2008 - 13:37
Thanks for your comments. The problem with this solution is I now have a management problem as I will have over 100 camera's in various locations throughout a campus environment and I would have to know which ports each of these camera's was on to disable the POE and also assume they would not get moved around at times to other ports which is highly unlikely.
Is there any issue with potential port damage on the Cisco switch if these mid span devices are used and the POE on the Cisco switch is enabled?
Thanks!
Giuseppe Larosa Tue, 12/30/2008 - 12:39
  • Hall of Fame,
    Founding Member
Hello Curtis,
I remembered that in one campus we have some outdoor Access points that have their own power injectors
see
http://www.cisco.com/en/US/docs/wireless/access_point/1520/power/guide/1520pwrinj.html#wp49664
it provides some suggestions
in our design document about wireless says that switch port connected to the power injector has to be configured with POE disabled.
Tomorrow I will check if it is so, but in your scenario with 100 devices this can be almost unmanageable we have 30 outdoor devices with power injector.
I would think of putting them in dedicated vlans so that a normal PC connected to it cannot access the intranet
(I imagine cameras are deployed for video surveillance so I would consider to put them in a VRF)
This is exactly what I'm afraid of.
The switch will try to detect if a POE device is on the port: if the power injector is well built it should not expose the resistance signature (25 Kohm) to the switch so POE should not be used on the switch port.
if the cameras also doesn't speak CDP or LLDP to ask power the switch under these two hyphotesis would be safe even if poe capable.
Cisco has started to introduce their own ip cameras
see
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6918/ps9692/ps9716/data_sheet_c78-492032.html
they don't mention a power injector.
on the slides of CIPT they show the midspan with a switch port non POE.
Sorry I cannot say yes you can do it.
I think in theory is possible to build a power injector that presents itself as a non PD device to the switch if has two ports and the correct electrical design.
searching with google I've found someone speaks of
PoE splitter (PD-AS-401/12).
see
http://www.electronicsnews.com.au/Article/PoE-splitter/170800.aspx
and for electronic details
http://www.powermanagementdesignline.com/howto/185300535;jsessionid=XVUWX4L5EYPROQSNDLPCKHSCJUNN2JVN?pgno=6
The unpowered CAT-5 cable plugs into the input (lower) jack (J1), and the injected 48 V power is placed on the unused (Alternative B) pair of wires that connect to the output (upper) jack (J2). This maintains the current midspan PSE convention, and prevents the 48 V from being connected to the unpowered switch or router. This solution does not include the detection and classification functions specified for a PSE by 802.3af, but that does not matter, since it is a temporary solution that only powers a single port.
however the author says it will not provide 48V to the switch port but nothing about what if some DC power comes from the switch to J1 (input).
This should at least protect from electrical damage the switch port but needs to be verified on your power injector data sheet.
Hope to help
Giuseppe
Giuseppe Larosa Tue, 12/30/2008 - 23:53
  • Hall of Fame,
    Founding Member
Hello Curtis,
I'm looking at an outdoor access point with a power injector
the POE is in auto mode but the operational state is off
SW-RM-SXR000-F-C4-1#sh power inline g3/24
Available:1400(w) Used:652(w) Remaining:748(w)
Interface Admin Oper Power(Watts) Device Class
From PS To Device
Gi3/24 auto off 0.0 0.0 LAP1510 n/a
Interface AdminPowerMax AdminConsumption
(Watts) (Watts)
Gi3/24 15.4 15.4
This confirms that the switch port can be left with auto configuration and doesn't need to have POE disabled
Hope to help
Giuseppe
ccorkern Thu, 01/01/2009 - 06:02
Giuseppe,
Thanks very much for your assistance with this. It does appear that all will be OK with this solution.
Thanks again!
Curt
