Routing protocol for MPLS
Dec 29th, 2008
We are planning to implement MPLS connectivity between our 3 offices and data center. Data center will have a access port of bandwidth 34 Mbps and other 2 offices with 10 Mbps and one office with 2 Mbps bandwidth.
From each office the MPLS is connected to Service provider Cloud.I have a choice of 3 routing protocols to use from the service provider.RIP II,OSPF,BGP.Which routing protocol to be used ?i have 2811 routers at each site.Is this fine ?I prefer to use OSPF but how in how many areas ?Is it fine to use a single area when service provider cloud is involved ?
Overall Rating: 4 (2 ratings)
Giuseppe Larosa Mon, 12/29/2008 - 13:59
you can use a single area design but I would prefer to use a non backbone area in each site with your CE router acting as ABR the whole SP cloud will be your area 0 backbone.
This because OSPF routes from other sites are imported as O IA not as O routes.
So it is better to reflect this on the OSPF topology.
Support of OSPF over the cloud is emulated via multi protocol BGP specific extended communities.
I would also consider to use BGP, being the easiest thing for the provider could have a lower price (but I understand they have given you three options at the same price).
I wouldn't consider RIP v2 in any case
Hope to help
tecnetpro Tue, 12/30/2008 - 00:07
i will have 2811 router on each site connecting to each 2811 site router will be a ABR with separate area connecting to a backbone area 0 on i getting it rt ?Can you please detail this ?.
Giuseppe Larosa Tue, 12/30/2008 - 00:19
an example can be
net internal to site
net 192.168.1x.0/24 backbone link on PE-CE
net 192.168.254.x/32 loopback in area 0
int loop0
ip address 192.168.254.x
desc OSPF router-id
router ospf 10
router-id 192.168.254.x
network 192.168.1x.0 area 0
network 192.168.254.x area 0
network area 1x
where x changes on each site: 1,2,3
Hope to help
