Negative impact of enabling flow control?
Dec 29th, 2008
  • Purple, 4500 points or more
Is there any negative impact of enabling flow control on a 3750? I noticed that it only supports inbound packets.
Thanks!
John
Edison Ortiz Mon, 12/29/2008 - 16:40
  • Hall of Fame,
    Founding Member
John,
No negative impact on the switch, however its usefulness depend upon the sending device as the switch can't send pause frames - it just receives it.
Please see the documentation for more info:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_46_se/command/reference/cli1.html#wp2233510
HTH,
__
Edison.
John Blakley Tue, 12/30/2008 - 06:20
Thank you for the reply Edison. I think the main question that my management had is if we can enable across all ports and get better throughput. I don't think it's a good idea to enable across all ports, but what are your thoughts?
John
Edison Ortiz Tue, 12/30/2008 - 07:41
  • Hall of Fame,
    Founding Member
Why do you feel this way after reading what it does?
My thoughts are, if you are experiencing congestion and dropped packets - Flow Control is a great tool to inform the sending partner to slow down its transmission. To me, that is a great benefit.
__
Edison.
John Blakley Tue, 12/30/2008 - 07:45
I don't necessarily "feel" that way. We don't have congestion on the network that requires this to be enabled, and I've read other forums where people have enabled it and it caused problems.
I always get concerned when I enable something that is disabled by default.
John
Edison Ortiz Tue, 12/30/2008 - 07:57
  • Hall of Fame,
    Founding Member
It's disabled by default because the behavior is hardware specific.
For instance, in the 3750 - it only allows you to receive pause frames, not send - while in the 6500 switch, you can send and receive pause frames.
Flow Control is just a quick and dirty QoS Layer2 mechanism - how do you feel about QoS? :)
__
Edison.
