HSRP explaination needed
Dec 29th, 2008
can someone with extensive HSRP experience tell me what this message means?
R1 F1/0 ip address 192.168.1.2/24
R2 E0/1 ip address is 192.168.1.3/24
HSRP ip address is 192.168.1.1
Linux host ip address is 192.168.1.13
Everything is connected to the same switch with VLAN 10.
config on R1 F1/0:
interface FastEthernet1/0
ip address 192.168.1.2 255.255.255.0
load-interval 30
duplex auto
speed auto
standby 10 ip 192.168.1.1
standby 10 priority 110
standby 10 preempt
standby 10 authentication cisco123
standby 10 name group1
Config on R2 E0/1:
interface Ethernet0/1
ip address 192.168.1.3 255.255.255.0
half-duplex
standby 10 priority 105
standby 10 preempt
R1#sh stand b
P indicates configured to preempt.
Interface Grp Prio P State Active Standby Virtual IP
Fa1/0 10 110 P Active local 192.168.1.3 192.168.1.1
R1#
R2#sh stand b
Et0/1 10 105 P Standby 192.168.1.2 local 192.168.1.1
R2#
Everything appears to be fine. However, tcpdump on the Linux host reveals the following:
[[email protected]-lab2 root]# tcpdump -nnn -i eth0 net 224.0.0.2 | grep unknown
tcpdump: listening on eth0
21:52:05.800864 192.168.1.3.1985 > 224.0.0.2.1985: HSRPv0-unknown (3) 16: state=initial group=2 [|hsrp] [tos 0xc0] [ttl 1]
21:52:33.909982 192.168.1.3.1985 > 224.0.0.2.1985: HSRPv0-unknown (3) 16: state=initial group=2 [|hsrp] [tos 0xc0] [ttl 1]
21:53:00.741247 192.168.1.3.1985 > 224.0.0.2.1985: HSRPv0-unknown (3) 16: state=initial group=2 [|hsrp] [tos 0xc0] [ttl 1]
21:53:28.682443 192.168.1.3.1985 > 224.0.0.2.1985: HSRPv0-unknown (3) 16: state=initial group=2 [|hsrp] [tos 0xc0] [ttl 1]
21:53:57.985459 192.168.1.3.1985 > 224.0.0.2.1985: HSRPv0-unknown (3) 16: state=initial group=2 [|hsrp] [tos 0xc0] [ttl 1]
21:54:26.639632 192.168.1.3.1985 > 224.0.0.2.1985: HSRPv0-unknown (3) 16: state=initial group=2 [|hsrp] [tos 0xc0] [ttl 1]
21:54:54.208061 192.168.1.3.1985 > 224.0.0.2.1985: HSRPv0-unknown (3) 16: state=initial group=2 [|hsrp] [tos 0xc0] [ttl 1]
22:02:32.895394 192.168.1.2.1985 > 224.0.0.2.1985: HSRPv0-hello 20: state=active group=10 addr=192.168.1.1 [tos 0xc0] [ttl 1]
22:02:32.995694 192.168.1.3.1985 > 224.0.0.2.1985: HSRPv0-hello 20: state=standby group=10 addr=192.168.1.1 [tos 0xc0] [ttl 1]
22:02:35.895322 192.168.1.2.1985 > 224.0.0.2.1985: HSRPv0-hello 20: state=active group=10 addr=192.168.1.1 [tos 0xc0] [ttl 1]
22:02:35.996345 192.168.1.3.1985 > 224.0.0.2.1985: HSRPv0-hello 20: state=standby group=10 addr=192.168.1.1 [tos 0xc0] [ttl 1]
As you can see R2 is sending out HSRP0-unknown. What does this mean? I see this
in both my lab and production environment. Is this something I should be concerned
with? Can someone explain this?
Richard Burts Mon, 12/29/2008 - 21:04
David
While I do not have a good explanation about what would cause this I believe that it is not something to worry about. The messages (and the show standby output) indicate that the configured HSRP is working as expected. I am not clear why R2 would generate these messages. But I notice that they are the initiation messages for group 2. I do not see anything that would cause the router to do anything about group 2, or why R2 would do it and not R1.
I am also puzzled about your output. If your command included this:
then how do you get this;
since it does not include the string unknown?
Rick
cisco24x7 Tue, 12/30/2008 - 03:57
"The messages (and the show standby output) indicate that the configured HSRP is working as expected."
How can you be sure? Just because it shows
that everything looks correct does not mean
that there are not issues. I see random
packetloss on my network which may or may not
berelated to this but I need to rule this out
as a potential cause.
To anwer your 2nd question, I have two
different tcpdump "tcpdump -nnn -i eth0 net 224.0.0.2" and "tcpdump -nnn -i eth0 net 224.0.0.2 | grep unknown" and combine the
output.
mlund Tue, 12/30/2008 - 05:42
As Rick already stated, it seems that there is a config like "standby 2 ". Perhaps a config left from earlier, that is not used anymore.
Please share the output of "show running interface Ethernet0/1", taken from R2.
/Mikael
cisco24x7 Tue, 12/30/2008 - 06:55
R2#sh run int e0/1
Building configuration...
Current configuration : 212 bytes
half-duplex
standby 10 ip 192.168.1.3
standby 10 preempt
end
R2#
John Blakley Tue, 12/30/2008 - 07:26
I agree with everyone else. It seems as though it's still looking for an old group 2. Maybe you should delete the HSRP config from R2 and recreate. Do you have any other HSRP configs on any of the other interfaces on this router?
HTH,
John
cisco24x7 Tue, 12/30/2008 - 07:44
"Do you have any other HSRP configs on any of the other interfaces on this router?"
NO
I performed the following on R2:
interface E0/1
no stand 10
no ip address
shut
(wait for 60 seconds)
standby 10 preempt
no shut
still has the same issue. Reboot ther router
several times with the same result.
John Blakley Tue, 12/30/2008 - 07:48
Are you connected to a layer 3 switch that has hsrp enabled on it? Tcpdump is getting it from somewhere. What happens if you debug hsrp on the router? Do you see the same error messages?
John
cisco24x7 Tue, 12/30/2008 - 07:53
everything is connected to a lay-2 3750 switch.
The switch is operating only in L2 mode. No L3.
tcpdump on the linux is getting it from the
router because this is multicast address.
Therefore, the linux server is definitely
seeing it from R2.
"debug stand events" and "debug stand packets"
shows me exactly what I am seeing on the Linux
box, minus the "HSRPv0-unknown"
cisco24x7 Wed, 12/31/2008 - 07:06
R2#sh debug
HSRP:
HSRP Events debugging is on
HSRP Packets debugging is on
R2#term mon
R2#
Dec 31 15:04:28.514: HSRP: Et0/1 Grp 10 Hello in 192.168.1.2 Active pri 110 vIP 192.168.1.1
R2#
Dec 31 15:04:29.532: HSRP: Et0/1 Grp 10 Hello out 192.168.1.3 Standby pri 105 vIP 192.168.1.1
R2#
Dec 31 15:04:31.511: HSRP: Et0/1 Grp 10 Hello in 192.168.1.2 Active pri 110 vIP 192.168.1.1
R2#
Dec 31 15:04:32.533: HSRP: Et0/1 Grp 10 Hello out 192.168.1.3 Standby pri 105 vIP 192.168.1.1
R2#
Dec 31 15:04:34.512: HSRP: Et0/1 Grp 10 Hello in 192.168.1.2 Active pri 110 vIP 192.168.1.1
R2#
Dec 31 15:04:35.534: HSRP: Et0/1 Grp 10 Hello out 192.168.1.3 Standby pri 105 vIP 192.168.1.1
Dec 31 15:04:35.878: HSRP: Et0/1 Redirect adv out, Passive, active 0 passive 1
R2#
Dec 31 15:04:37.513: HSRP: Et0/1 Grp 10 Hello in 192.168.1.2 Active pri 110 vIP 192.168.1.1
R2#
Dec 31 15:04:38.535: HSRP: Et0/1 Grp 10 Hello out 192.168.1.3 Standby pri 105 vIP 192.168.1.1
R2#
Dec 31 15:04:40.510: HSRP: Et0/1 Grp 10 Hello in 192.168.1.2 Active pri 110 vIP 192.168.1.1
R2#
Dec 31 15:04:41.536: HSRP: Et0/1 Grp 10 Hello out 192.168.1.3 Standby pri 105 vIP 192.168.1.1
R2#
Dec 31 15:04:43.511: HSRP: Et0/1 Grp 10 Hello in 192.168.1.2 Active pri 110 vIP 192.168.1.1
R2#
Giuseppe Larosa Wed, 12/31/2008 - 07:20
Hello David,
what if you add a PC with ethereal or wireshark on another port in the same VLan to compare the results of packet capture ?
Because there is no trace of standby 2 on R2 a third party could help to understand who's right here.
Hope to help
Giuseppe
cisco24x7 Wed, 12/31/2008 - 07:39
Giuseppe,
There are only three devices connected to a
stand-alone L2 switch, R1, R2 and the Linux
server. The switch is a 3550 switch and a
single VLAN 1.
I do not understand of adding another PC with
ethereal. I can accomplish the same on a linux
server using ethereal as well. I can
connect another Linux server and run capture multiple capture/tcpdump
Giuseppe Larosa Wed, 12/31/2008 - 09:23
Hello David,
the suggestion is that adding a third point of view.
you can add a linux box as well I would use a different software just to have some differences
Hope to help
Giuseppe
John Blakley Wed, 12/31/2008 - 10:38
Can you post the debugs from R1? In your R2 post, I don't see where it's trying to find a group 2, but I see it in your tcpdump. You also said that this one system is going into a 3750 that's configured as a L2 switch. So, you have:
linux --> switch --> router
There's nothing in-between?
Richard Burts Wed, 12/31/2008 - 10:53
John
While it might be interesting to see debugs from R1 the tcpdump output clearly shows the source address as being from R2.
David
I am quite puzzled that the tcpdump is reporting these packets but that the debug from R2 does not show R2 sending them. I am beginning to think that some other device (and perhaps some other utility) looking at the traffic might be helpful.
[edit] it is also very puzzling that the mystery packets are for HSRP group 2 but there is no configuration of group 2 on R2.
Rick
cisco24x7 Wed, 12/31/2008 - 11:34
Trust me when I say that there are only 3
devices connected to the L2 switch. I know
because I removed everything else. Still have
the same issue.
cisco24x7 Wed, 12/31/2008 - 11:35
Think of the switch as a dumb HUB. All three
devices, R1, R2 and linux connect to the same
VLAN 1 on the switch.
cisco24x7 Wed, 12/31/2008 - 17:28
yes, it is still an issue. Any ideas on how
to stop R2 from sending out "unknown" HSRP-v0?
insccisco Wed, 12/31/2008 - 17:32
No, I actually just started playing with HSRP. But if it looks like all is working and this is clearly an unexpected behavior, I would suggest to check at the IOS bug releases, perhaps you're hitting one and by upgrading the IOS will "fix" the issue....
pfillips11 Fri, 01/02/2009 - 06:59
What does show stand show on both R1 and R2?
If R2 is really sending something then it should show the initial HSRP state.
The debugs somehow do not indicate that its sending anything.
crow930us Mon, 01/12/2009 - 23:03
How often do you see these messages? Are they only at startup or do they occur over a certain period of time or after you finish some configuration changes?
The reason I ask is because the initial phase is when HSRP either first comes up on an interface or when there is a configuration change done on an interface. Obviously the HSRPv0-unknown would be there if HSRP is first coming up. The default group for HSRP is 0 and you have a configured HSRP group of 10, so I'm not sure where the group=2 part is coming from.
The last 4 lines of output is where the two devices decide which is going to be the active router and the standby router, which is verified by the priorities assigned on each interface.
I didn't see anyone mention anything about the different states that HSRP goes through when it first starts up. To me the HSRPv0-unknown would be a normal message when the interface is first configured with HSRP or a change on the interface.
