issue with 1131 AP
Dec 29th, 2008
AP 1130 (Autonomous) is converted in to LWAP and it has go the recovery image of “c1130-rcvk9w8-tar.123-7JX”
We tried to associate with WLC in L3 mode by enabling DHCL option 43, LAP is initially getting associated with WLC and downloading the latest software from WLC after that it's getting disconnected from the WLC
Scott Fella Tue, 12/30/2008 - 07:21
Verify the time is set correctly on the wlc. Also, post the log when you are consoled into the ap, so we can see the error, unless the time setting fixes your issues. Check the country code on both the wlc and ap also.
kylerossd Mon, 01/05/2009 - 20:59
Additionally to what fella5 said I would also add that you might have to allow self signed certificates, as you said you converted it from IOS to LAP
