cisco AIR-LAP1242G-A-K9 cannot access Global mode
Dec 29th, 2008
Dear Sir,
I am using cisco AIR-LAP1242G-A-K9 wireless access point by console port, i can login to AP in user and previllige mode. but when every i try to access global mode its says % Invalid input detected at '^' marker. i cannt access any fastthernet or BVI interface.
mentioned below is the copy paste of screen and show version.
AP001e.be26.a7e2#config t
OR
AP001e.be26.a7e2#configure terminal
show version
Cisco IOS Software, C1240 Software (C1240-RCVK9W8-M), Version 12.3(11)JX1, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:44 by alnguyen
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE
(fc2)
AP001e.be26.a7e2 uptime is 20 hours, 54 minutes
System returned to ROM by reload
System image file is "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx"
cisco AIR-LAP1242G-A-K9 (PowerPCElvis) processor (revision A0) with 24566K/81
92K bytes of memory.
Processor board ID FTX1218B4RL
PowerPCElvis CPU at 266Mhz, revision number 0x0950
Last reset from reload
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Please advice what needs to be done.
i will really appreciate your assistance.
CFayNTAdmin83 Tue, 12/30/2008 - 05:01
Based on whats listed above, you have an LWAPP image on the AP. This means that the AP runs in lightweight mode and registers to a controller. I know a lot of the commands are disabled in this mode. If you don't use a Wireless Lan Controller then you need to do the TFTP recovery to Autonomous mode on the AP. Once that is done you will be able to issue standard commands to configure the ethernet and radio interfaces.
mark.cronin Tue, 12/30/2008 - 07:26
Not sure if you are using a Wireless LAN Controller, but if you are it is possible to change the default username and password for your LWAPs from Cisco cisco by using the following command on the controller
config ap username password
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
