Can not Access Access Point Global Mode
Dec 29th, 2008
Dear Sir,
I am using cisco AIR-LAP1242G-A-K9 wireless access point by console port, i can login to AP in user and previllige mode. but when every i try to access global mode its says % Invalid input detected at '^' marker. i cannt access any fastthernet or BVI interface.
mentioned below is the copy paste of screen and show version.
AP001e.be26.a7e2#config t
OR
AP001e.be26.a7e2#configure terminal
show version
Cisco IOS Software, C1240 Software (C1240-RCVK9W8-M), Version 12.3(11)JX1, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:44 by alnguyen
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE
(fc2)
AP001e.be26.a7e2 uptime is 20 hours, 54 minutes
System returned to ROM by reload
System image file is "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx"
cisco AIR-LAP1242G-A-K9 (PowerPCElvis) processor (revision A0) with 24566K/81
92K bytes of memory.
Processor board ID FTX1218B4RL
PowerPCElvis CPU at 266Mhz, revision number 0x0950
Last reset from reload
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Please advice what needs to be done.
i will really appreciate your assistance.
Rob Huffman Tue, 12/30/2008 - 07:17
Hi Zeeshan,
The problem here is that the model you are using ( AIR-LAP1242G-A-K9 )
is a Lightweight or LWAPP AP not an Autonomous AP that can be configured using the method you are trying. This is a very common problem that should be quite fixable :)
Here is the related info :)
Using a TFTP Server to Return to a Previous Release
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
Hope this helps!
Rob
